Table join to json data?
4881
11-13-2014 06:20 PM
RowanWinsemius
Hi there,
I've often used the standard join tool to join spatial data with a table however Im wondering if its possible to setup a join to json data which represents a table? The scenario is I have a google sheet (like an excel but in the cloud), within ArcGIS desktop I'd like to be able to run my join on to this data which I can I can access via json... Can anyone suggest any ideas as to how this might be feasible?
Cheers,
Rowan
PS I can't find a regular ArcGIS Desktop forum so I'm posting here sorry..
TimGowner
Perhaps it would be helpful to first import the JSON into a spreadsheet as well then match them up in the same spreadsheet.  You can use a tool like https://json-csv.com‌ to convert the JSON.
RowanWinsemius
Thanks for the suggestion Tim but I was hoping to be able to have it as a live join rather than converting it to a static data source like a csv.
Cheers
XanderBakker
Esri Esteemed Contributor
Maybe you find the necessary information in this website:
Python Example - Google Cloud Storage — Google Cloud Platform
Kind regards, Xander
XanderBakker
You could use some Python code to retrieve the JSON from Google Docs and join it using python (arcpy) to a featureclass.
And yes, you should probably move this to a different place, since installation support has nothing to do with your question.
