How to find x,y of the point on the line feature in ArcGIS Runtime SDK for .Net?
3876
11-13-2014 04:27 PM
AnatoliiTerentiev
Dear Gurus!
There is a table of bridges, each bridge record specified identifier of the road and a kilometer from the beginning. How to determine the x,y coordinates of a bridge with help of ArcGIS Runtime SDK for .Net or any other lib? I use c# in .net.
MichaelBranscomb
Esri Frequent Contributor
The scenario you are referring to is typically referred to as Linear Referencing. You have not said what type of app you are building (Desktop, Store or Phone) but for any of those APIs you may be able to find a way to achieve this with the GeometryEngine: GeometryEngine Class
If you are using the Desktop API you also have the LocalServer available which supports the following Geoprocessing tools for Linear Referencing:
Calibrate Routes
Create Routes
Dissolve Route Events
Locate Features Along Routes
Make Route Event Layer
Overlay Route Events
Transform Route Events
The tool which would help is is 'Locate Features Along Routes': ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Once you have created your geoprocessing model/script you will need to package it for use in the ArcGIS Runtime - ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Cheers
Mike
MichaelBranscomb
Calibrate Routes
Create Routes
Cheers
Mike
AnatoliiTerentiev
Exhaustive answer, thank you very much, Michael!
