Support a ListCollectionView for a GraphicsLayer GraphicSource (WPF/.NET)
3567
11-12-2014 07:58 AM
EricPaitz
The WPF ListBox supports filtering by using a ListCollectionView or an ICollectionView and defining the Filter Predicate of the View. This allows several views to be created against the same source collection. The same functionality needs to be supported with the GraphicsLayer and its GraphicSource.
Something like the following.
Graphics = new ObservableCollection<Graphic>();
GraphicsView = new ListCollectionView(Graphics);
GraphicsView.Filter = new Predicate<object>(GraphicsViewFilter);
private bool GraphicsViewFilter(object item){
   return true;  //Custom filter logic goes her
Binding binding = new Binding("GraphicsView") { Source = ViewModel };
BindingOperations.SetBinding(graphicsLayer, GraphicsLayer.GraphicsSourceProperty, binding);
This would allow many GraphicsLayers to be created against a single source Collection but display different results.
See more at: http://ideas.arcgis.com/ideaView?id=087E00000005HKC&returnUrl=%2Fapex%2FideaList%3Fc%3D09a300000004x...
DominiqueBroux
Esri Frequent Contributor
GraphicsSource can be any enumerable of Graphics so you can create your own class that implements IEnumerable<Graphic> and subclasses CollectionView.
Something like:
public class GraphicsCollectionView : ListCollectionView, IEnumerable<Graphic>
   public GraphicsCollectionView(ObservableCollection<Graphic> graphics) : base(graphics)
   public new IEnumerator<Graphic> GetEnumerator()
     return this.OfType<Graphic>().GetEnumerator();
Then you can use it as you proposed:
var graphicsView = new GraphicsCollectionView(Graphics);
graphicsView.Filter = new Predicate<object>(GraphicsViewFilter);
graphicsLayer.GraphicsSource = graphicsView;
DominiqueBroux
Something like:
EricPaitz
Hey Dominique, thank you very much for this explination. I was able to get this to work in a test project. Very cool! 🙂
