Hi Peoples,
I have created a web map in ArcGIS Online that has two layers. The top layer is a cached map service, which goes down to level 18, and the basemap is a cached image service that goes down to level 19.
When I create a Spy Glass app from the map, the app allows me to zoom down to level 18, at which point all is good, but then it allows me to zoom to level 19, in which case I have data in the basemap, but not in the top layer. The result is there is no data in the spy glass, which looks a bit average.
I need to be able to tell the app that level 18 is the most it should zoom into.
Anyone know how to achieve this with the app hosted in ArcGIS Online?
Cheers,
Mark
Hi Mark,
in the swipe app, which builds on the same application as the spyglass app, you can add a "maxZoom" parameter in the mapOptions of Core.js. I guess the same should work in the spyglass-code.
E.g.:
arcgisUtils.createMap(webmapId, divId, {
mapOptions: {
slider: divId != "lensMapNode",
autoResize: false,
infoWindow: app.popup[index],
showAttribution: divId != "lensMapNode",
minZoom: 1,
maxZoom: 11,
usePopupManager: true
kind regards,
Flo
Hi Flo,
I am hosting in ArcGIS Online, and thus I don't think I have access to the code.
In this case, the level looks to be determined by the basemap, and you are not able to alter the value in the online app provided.
Cheers,
Mark
Hi Mark,
as far as I know you are right - you need to download the app´s code and host it on our own.
best regards,
Flo
