Tweak Geocoder Widget to Activate Layer Popup?
4333
7
11-04-2014 01:55 PM
BrianO_keefe
Honored Contributor
What I want is the following:
  1. User enters their address into Custom-Geocoder Input Field
  2. Address is found
  3. Instead of 'Location' popup window that just shows the address searched for...
  4. Cause a click to happen at the coords where the 'Location' popup was going to fire
How difficult would this be?
I would PREFER this to be a custom widget so that I could choose to add this to projects that ALREADY have the GeoCoder. Kinda like a GeoFinder widget?
Any ideas?
BrianO_keefe
Honored Contributor
I kind of thought it might have to modified in the 'onFindResults' method inside of Widget.js
      onFindResults: function(results) {
        //Check to see if the user typed an MGRS or USNG string
        this.lastMgrsResult = this.lookupMgrs(results.results.value);
        if (null !== this.lastMgrsResult) {
          // Get reference ellipsoid coordinates of the current coordinate system
          // var mapWkid = this.map.spatialReference.wkid;
          // var srWkid = csUtils.isProjectedCS(mapWkid) ?
          //csUtils.getGeoCSByProj(mapWkid) : mapWkid;
          //Make a new object just like the objects in results.results.results
          var point = new Point(
            this.lastMgrsResult.longitude,
            this.lastMgrsResult.latitude,
            new SpatialReference({
              wkid: 4326 //srWkid   should use the ellipsoid SR of the current coordinate system
          var extent = this.map.extent.centerAt(point);
          var feature = new Graphic(point);
          var resultObject = {
            extent: extent,
            feature: feature,
          //Insert at start of results list
          results.results.results.unshift(resultObject);
I tried commenting out from var extent on and it didn't seem to affect the widget... so maybe I'm wrong?
StevenGraf1
You may want to check out this application created by Tim Witt.  This populates several text boxes with coordinate information based on an address search and vice versa.
Steven
RobertScheitlin__GISP
Brain,
   Was this meant to be in the Web AppBuilder for ArcGIS‌ space?
BrianO_keefe
Honored Contributor
I'm not actually sure Robert. I thought this might just be a Javascript API question but I suppose since it is a GeoCoder Widget from WAB that I'm referencing then maybe it should be? How do I move it?
Brian,
   The GeoCoder dijit component is doing what it is designed to do, what you are attempting to do is customize the Geocoder widget of the WAB to handle the result differently, so yes this does belong in the WAB space or here in the WAB custom widgets group. What you are wanting to do is not a simple couple of lines of code kind of change. The way I see it you would need to get the coordinates of the geocoded address and use them to programmatically fire a mouse click event. Well the question is would this new click event be emitted for the map or the Layer ( I don't actually know the answer to that one). It would require some testing to see if you could programmatically cause a layers popup to fire based on an XY. I don't have the answers for you but maybe this will help with a plan of attack for your development.
BrianO_keefe
Honored Contributor
I see.
That's right. I forget. The Geocoder widget folder doesn't actually hold ALL of the widget code for that widget.
Hmmmm.... back to the drawing board.
by Anonymous User
Not applicable
I do this on my site www.sagis.org/map
This is WAB 2.12 but worked since 2.8 as well.  Add the few lines /// kevin /// section between these comments, is what I added.
/////////////// snipped////////
* Mehtods for control result menu
_onSearchDijitClick: function() {
this._resetSelectorPosition('.searchMenu');
_onSelectSearchResult: function(evt) {
var target = evt.target;
while(!(html.hasAttr(target, 'data-source-index') && html.getAttr(target, 'data-index'))) {
target = target.parentNode;
var result = null;
var dataSourceIndex = html.getAttr(target, 'data-source-index');
var dataIndex = parseInt(html.getAttr(target, 'data-index'), 10);
// var sources = this.searchDijit.get('sources');
if (dataSourceIndex !== 'all') {
dataSourceIndex = parseInt(dataSourceIndex, 10);
if (this.searchResults && this.searchResults[dataSourceIndex] &&
this.searchResults[dataSourceIndex][dataIndex]) {
result = this.searchResults[dataSourceIndex][dataIndex];
this.searchDijit.select(result);
//////kevin m  customized code
setTimeout(lang.hitch(this, function () {
// added by me
var mpPt;
if (result.feature.geometry.type === "point") {
mpPt = result.feature.geometry;
} else {
mpPt = result.feature.geometry.getExtent().getCenter();
var scrPt = this.map.toScreen(mpPt);
this.map.emit("click", { bubbles: true, cancelable: true, mapPoint: mpPt, screenPoint: scrPt });
// end of added by me
}), 100);
_hideResultMenu: function() {
query('.show-all-results', this.searchResultsNode).style('display', 'block');
query('.searchMenu', this.searchResultsNode).style('display', 'none');
_showResultMenu: function() {
html.setStyle(this.searchResultsNode, 'display', 'block');
