Basemaps not showing with Beta 3
3217
8
11-04-2014 06:57 AM
mpboyle
I created and downloaded my first app using Beta 3 and none of our basemaps show in the basemap widget.  They all appear when I configure the basemap widget, but if I click on the basemap widget within the app builder or after downloaded, nothing shows.
Has anyone else experienced this?...or have any suggestions what the issue is?
StanMcShinsky
I had the same issue. I went to the config_Basemap.json file and removed the empty tags like {}, (line 75 in your file) and it worked again.
mpboyle
...below is the code within the config_Basemap.json file...
  "basemapGallery": {
    "basemaps": [
        "layers": [
            "id": "baseImagery2012_8036",
            "opacity": 1,
            "visibility": true,
            "url": "http://gis.linncounty.org/arcgis/rest/services/PublicBase/baseImagery2012/MapServer"
        "title": "2012 Imagery Base",
        "thumbnailUrl": "http://linncounty-gis.maps.arcgis.com/sharing/rest/content/items/11083efc958c43fd90980dc2869b05b7/in...",
        "spatialReference": {
          "wkid": 102675,
          "latestWkid": 3417
        "layers": [
            "id": "baseImagery2012_3805",
            "opacity": 1,
            "visibility": true,
            "id": "baseImageryLabels_8314",
            "isReference": true,
            "opacity": 1,
            "visibility": true,
            "url": "http://gis.linncounty.org/arcgis/rest/services/PublicBase/baseImageryLabels/MapServer"
        "title": "2012 Imagery with Labels Base",
        "thumbnailUrl": "http://linncounty-gis.maps.arcgis.com/sharing/rest/content/items/eafdcd8eb4e74e489cdc97b76304d3df/in...",
          "wkid": 102675,
          "latestWkid": 3417
        "layers": [
            "id": "baseMapLinnCountyCadastral_8931",
            "opacity": 1,
            "visibility": true,
            "url": "http://gis.linncounty.org/arcgis/rest/services/PublicBase/baseMapLinnCountyCadastral/MapServer"
        "title": "Cadastral Base",
        "thumbnailUrl": "http://linncounty-gis.maps.arcgis.com/sharing/rest/content/items/2cab862785c849a0bd3620e5639ab135/in...",
          "wkid": 102675,
          "latestWkid": 3417
        "layers": [
            "id": "baseMapLinnCountyGray_9319",
            "opacity": 1,
            "visibility": true,
            "url": "http://gis.linncounty.org/arcgis/rest/services/PublicBase/baseMapLinnCountyGray/MapServer"
        "title": "Grayscale Base",
        "thumbnailUrl": "http://linncounty-gis.maps.arcgis.com/sharing/rest/content/items/44b0d0424b3e447a8ddbf8a8eafee595/in...",
          "wkid": 102675,
          "latestWkid": 3417
        "layers": [
            "id": "baseMapLinnCounty_3680",
            "opacity": 1,
            "visibility": true,
            "url": "http://gis.linncounty.org/arcgis/rest/services/PublicBase/baseMapLinnCounty/MapServer"
        "title": "Standard Base",
        "thumbnailUrl": "http://linncounty-gis.maps.arcgis.com/sharing/rest/content/items/300a7d7706724daa8e5f233cbc939791/in...",
          "wkid": 102675,
          "latestWkid": 3417
        "layers": [
            "id": "baseMapLinnCountyTopo_2671",
            "opacity": 1,
            "visibility": true,
            "url": "http://gis.linncounty.org/arcgis/rest/services/PublicBase/baseMapLinnCountyTopo/MapServer"
        "title": "Topographic Base",
        "thumbnailUrl": "http://linncounty-gis.maps.arcgis.com/sharing/rest/content/items/e993542284d949cdba83687a25a0a205/in...",
          "wkid": 102675,
          "latestWkid": 3417
RobertScheitlin__GISP
Matthew,
   In Beta 3 the ability to specify baseamps and operational layers in the main config.json has been partially removed and broken. I don't know if there are any concrete plans to fix this or not in the final release.
mpboyle
Is there a way to get our basemaps to show in the basemap widget...?
Matthew,
   I can get the basemap gallery widget to use the basemaps from my server as long as they have the same spatial ref as the webmap that I am using
mpboyle
Our basemaps are all in State Plane, as are the services overlaid on our basemaps.  Is there something in the code where the WKIDs are off...?
Matthew but is your WebMap that you begin the whole Web AppBuilder application preparation (when on the map tab), does that web map use state plane? I have been completely unsucessful in using a state plane web map and then trying to use state plane basemaps in the basemap gallery widget (at least in  Beta 3).
StanMcShinsky
mpboyle
Stan McShinsky‌ - that did it, thanks for the tip!
