.pyt spatial reference help?
2290
5
10-29-2014 08:50 AM
KevinBell
I need to make a python toolbox that takes a Lat, Long, buffer distance and returns a list of addresses.  I'm getting hung up on the spatial reference right now.  The buffer is created, but has no SR...   hmmm...  what am I doing wrong here?
import arcpy
import os
WKID = 4326 # WGS-1984
sr = arcpy.SpatialReference()
sr.factoryCode = WKID
sr.create()
arcpy.env.outputCoordinateSystem = sr
class Toolbox(object):
    def __init__(self):
        self.label = "Get Nearby Addresses"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [GetNearbyAddresses]
class GetNearbyAddresses(object):
    def __init__(self):
        self.description = "Get Nearby Addresses within a buffer."
        self.canRunInBackground = False
    def getParameterInfo(self):
        params = []
        param0 = arcpy.Parameter(
            displayName = "Latitude",
            name = "lat",
            datatype = "Long",
            parameterType = "Required",
            direction = "Input")
        params.append(param0)
        param1 = arcpy.Parameter(
                    displayName = "Longitude",
                    name = "lon",
                    datatype = "Long",
        params.append(param1)
        param2 = arcpy.Parameter(
            displayName = "Buffer Distance",
            name = "distance",
            datatype = "Long",
        params.append(param2)
        param3 = arcpy.Parameter(
                    displayName = "Address List",
                    name = "addresses",
                    datatype = "GPString",
                    parameterType = "Derived",
                    direction = "Output")
        params.append(param3)
        return params
    def execute(self, parameters, messages):
        try:
            arcpy.env.workspace = r'E:\gis\default.gdb'
            lat = parameters[0].valueAsText
            lon = parameters[1].valueAsText
            distance = parameters[2].valueAsText
            inpoint = arcpy.Point(X=lon, Y=lat)
            ptGeometry = arcpy.PointGeometry(inpoint)
            arcpy.Buffer_analysis(ptGeometry, 'buffer', distance, \
                                  "FULL", "ROUND", "NONE", "")
            print 'made the buffer.'
        except Exception, ErrorDesc:
            sErr = "ERROR:\n" + str(ErrorDesc)
            messages.addErrorMessage(sErr)
        return
JasonScheirer
Esri Alum
Get rid of that whole part at the top of your script where you create the sr and set the environment. It'll only get executed once and may get clobbered by anything else. Instead set it on the point:
ptGeometry = arcpy.PointGeometry(inpoint, arcpy.SpatialReference(4326))
JasonScheirer
Esri Alum
KevinBell
Thanks much Jason!
Now that I have the polygon in the correct location I'll use a search cursor to get intersecting addresses as text, and I need to simply return them as a comma separated string.  Building the string up will be easy enough.
I want to publish this as a GP service so that we call it passing the lat/lon/buffer as parameters, and then return my address list.
Are my Param3 datatype and direction correct?  How would I return the string from passing those parameters?
JasonScheirer
Esri Alum
Yes. You'd do parameters[3].valueAsText = "returnvalue".
KevinBell
thanks.  I added parameters[3].valueAsText = 'laksdjflaskdjflksajdf' after the buffer code but I got an error saying:
ERROR:
ParameterObject: Set attribute: valueAsText does not exist
while this is still happening on the desktop rather from the server I'm unsure how I'd get the text back.  Would it print out in the gp window?
JasonScheirer
Esri Alum
Oh, then use value rather than valueAsText.
