UpdateCursor - sequence size?
2875
10-29-2014 08:32 AM
BenLeslie1
I'm trying to use UpdateCursor to insert some text into an attribute.  The attribute is a text field ten characters in length.  However the script will only work for values of one character in length.
i.e. if MyValue = "A" the script works
but if MyValue = "All" the error says 'sequence size must match size of the row'
with arcpy.da.UpdateCursor(MyFeatureLyr, MyAttribute) as cursor:
     for row in cursor:
          cursor.updateRow(MyValue)
DallasShearer
the updateRow needs to be sent a tupple even if it's only one variable being sent.
change the updaterow to this and it should work
cursor.updateRow((MyValue,))
DallasShearer
DanPatterson_Retired
The help files says lists or tuples can be used for parameters that require them, see da.UpdateCursor help   if so, I would do it explicitly using the list and tuple methods
>>> a= list('astring')
>>> a
['a', 's', 't', 'r', 'i', 'n', 'g']
>>> b = tuple('astring')
>>> b
('a', 's', 't', 'r', 'i', 'n', 'g')
or in your case list(MyValue) or tuple(MyValue) in the appropriate line(s)
JoshuaBixby
MVP Esteemed Contributor
I don't think using the list or tuple function in the way described here will yield the desired result.  In the original code snippet, I understand MyAttribute to be a single field/attribute, and that the goal is to populate that attribute with "ALL" or some other multi-character string.  Since a multi-character string is iterable, passing MyValue to the tuple function will result in a tuple with multiple single-character items instead of a tuple with a single multi-character items, as demonstrated.
The suggestion by Dallas Shearer‌ works since it passes the update cursor a single item multi-character tuple, which is what I think the OP is after.
I agree...I guess my point wasn't clear...sorry...
Manually create the tuple from a string, requires entering the , directly
>>> a = ("astring",)  # create the tuple directly
>>> a
('astring',)
If you have a list of string already
>>> a = ["astring"]
>>> b = tuple(a)
>>> b
('astring',)
If you just have a string, in either case of the tuple or list, you still have to add the string to it otherwise the string is treated as the iterable
