Using python to replace subtypes with descriptions
2522
10-29-2014 07:07 AM
DirkPeterson
I have a workflow that wil use a definition query to select a subset of point data that will be exported from SDE to a 3rd party.  One of the attributes is a subtype where there are 14 subtypes.  When I export the data, the subtype remains as a number rather than a description.  What I need to do is come up with a python expression to replace all of the different subtype numbers with the descriptions.  I have found where I can replace subtype with the description, but how do I do all of them at once?
This is what I came up with:
!Fieldname!.replace("subtype1","description1").("subtype2","description2")........("subtype14","description14)
When I run this, I get a ERROR 000539
I'm new to Python so any help would be appreciated.
DirkPeterson
I just figured out between each I need to have .replace instead of just a .
DirkPeterson
Zeke
Honored Contributor
What is the field type? If it's numeric (since you mention number), you can't put a string into it. Otherwise, I don't think you can run a multiple replace in one line like that; at least, I've never seen it.
Assuming this is in Field Calculator, set the parser to Python and check Show Codeblock. In Pre-Logic Script Code, enter something like:
def DoThis(myField):
    if myfield == '1':
        val = 'description1'
    elif myfield == '2':
        val = 'description2'
    elif myfield == '3':
        val = 'description3'
    elif myfield == '14':
        val = 'description14'
    else:
        val = 'somedefaultvalue'
    return val
In the Fieldname = box, enter
DoThis(!Fieldname!)
This assumes that Fieldname is text. If not, you'll have to add a new text field and calculate that instead.
There are other ways to handle this; you could add subtypes or domains to your new feature class, for example, but the above should work ok.
