Print resolution default
2854
10-28-2014 04:17 PM
Ulises
Is there a way to set a default print resolution (dpi) for the print widget in webapp builder?  Can't find anything looking at the available attributes in the configuration json file or anywhere else.
Ulises Feliciano Troche
RobertScheitlin__GISP
Ulises,
  This is not configurable in the json but here is where you can change it in the code source. Find the client\stemapp\widgets\Print\templates\Print.html and find this line:
<input type="text" data-dojo-type="dijit/form/NumberTextBox" data-dojo-props="name:'dpi',required:true,value:300,style:'width:100px;'"/>
change the data-dojo-props value, by default it is 300 as you can see.
Ulises,
Ulises
Thanks, Robert...and keep up the awesome work!!!
have a good one.
