ArcObjects - Error in cast an IGeometry object
4146
10-27-2014 08:07 AM
ShaningYu
Honored Contributor
Referring to the code at
' http://stackoverflow.com/questions/9212398/how-to-determine-whether-a-geometry-is-multi-part
static bool IsMultiPart(this IGeometry geometry{
var geometryCollection = geometry as IGeometryCollection;
return geometryCollection != null && geometryCollection.GeometryCount > 1;
I wrote a piece of VBA as below, but got a compiling error (Sub or Function not defined) at the line as highlighted below.  What's wrong in this piece of code?  Appreciate if you can point out.
Function IsMultiPart(geo As IGeometry)
    Dim b As Boolean
    Dim geometryCollection As IGeometryCollection
    Set geometryCollection = CType(geo, IGeometryCollection)
    If geometryCollection <> Null And geometryCollection.GeometryCount > 1 Then
        b = True
    Else
        b = False
    End If
    IsMultiPart = b
End Function
ShaningYu
Honored Contributor
by adding the following, the problem was gone.  Thanks.
        Set pCurve = pFeature.Shape
        Dim mAware As IMAware
        Set mAware = pCurve
        mAware.mAware = True
        Dim seg As IMSegmentation3
ShaningYu
Honored Contributor
I revised the code like that below, but got error at the highlighted line: The geometry is not M-aware.  Appreciate if you can help this issue - How to make the IMSegmentatione object as M-awared.
Sub CheckSegments()
    Dim pDoc As IMxDocument
    Set pDoc = ThisDocument
    Dim pMaps As IMaps
    Set pMaps = pDoc.Maps
    Dim pMap As IMap
    Set pMap = pMaps.Item(0)
    Dim pLayer As ILayer
    Dim pFLayer As IFeatureLayer
    Dim sFCName As String
    sFCName = "GIS_RAIL_TRK_SEG_LIN"
    Dim i As Integer
    For i = 0 To pMap.LayerCount - 1
        If pMap.Layer(i).Name = sFCName Then
            Set pLayer = pMap.Layer(i)
            If TypeOf pLayer Is IFeatureLayer Then
                Set pFLayer = pLayer
                Exit For
            End If
        End If
    Next i
    Dim pFClass As IFeatureClass
    Set pFClass = pFLayer.FeatureClass
    Dim pQFilter As IQueryFilter
    Set pQFilter = New QueryFilter
    pQFilter.WhereClause = "[TRACK_TYPE] LIKE 'MAIN TRACK'"
    Dim pFCursor As IFeatureCursor
    Set pFCursor = pFClass.Search(pQFilter, False)
    Dim pCurve As ICurve, pFeature As IFeature
    Set pFeature = pFCursor.NextFeature
    Do Until pFeature Is Nothing
        If pFLayer.FeatureClass.ShapeType = esriGeometryPolyline Then   ' esriGeometryPolyline-3  esriGeometryLine-13
            Set pFeature.Shape = pCurve
            Set seg = pFeature.Shape      'pCurve
            If seg.MMonotonic <> esriMMonotonicEnum.esriMNotMonotonic Then
                Debug.Print
            End If
        End If
    Loop
End Sub
ShaningYu
Honored Contributor
        Set mAware = pCurve
