Deploy JavaScript application within IIS
1984
10-23-2014 03:17 AM
ConstancioAmurrio_García
Hello to everyone.
I've developed an application using the ESRI's JavaScript API. My web services are deployed in an ArcGIS Server 10.2 machine. These services are working properly through a web adaptor and I can access the admin interface externally (using sitename.com/arcgis/rest/services).
Due to economical restrictions I have to deploy the app in the same machine where the services and the web adaptor are. By now, I have created a site in IIS and I am able to run it locally (localhost/sitename). The problems come when I try to use my sitename (and not localhost) to access the application. I want to use the web adaptor name for both the services interface and the application itself. I've tried few things:
  • If I set the web adaptor pool to my application site, I am able to load the application locally on the server (using sitename.com), but the application is not totally loaded. Some of its resources throw a 503 error.
  • Using the web adaptor pool does not allow external access (503 error again). It is not a firewall issuee because I've set an inbound rule.
  • I've checked multiple configurations of the pool without success.
Does anyone have an idea on how to deploy, on the same machine, a Javascript application and give external access to it using the site name (the web adaptor name)? I have been taking a look to many resources without success.
Thanks in advance and sorry if these kind of questions are too obvious.
Regards.
Constan.
