I need help with this error
3971
5
10-21-2014 02:03 PM
TrevorFugate
  File "C:\Python27\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
    exec codeObject in __main__.__dict__
  File "E:\GEO501\Exercise07\Results\printvalues.py", line 1, in <module>
    import arcpy
ImportError: No module named arcpy
Here is the code:
import arcpy
from arcpy import env
env.workspace = "C:/EsriPress/Python/Data/Exercise07"
fc = "airports.shp"
cursor = arcpy.da.SearchCursor(fc, ["NAME"])
for row in cursor:
print "Airport name = {0}".format(row[0])
Tags (3)
JasonScheirer
Esri Alum
Is ArcGIS installed on your machine? Which version? Did you install Python yourself?
TrevorFugate
Yes for both.
TrevorFugate
ArcGis 10.1 and python 2.7
JasonScheirer
Esri Alum
That is probably the problem. You installed Python after installing ArcGIS? You've probably messed up your installation now, you may want to uninstall both and reinstall just ArcGIS.
As a hack, you may be able to run C:\Python27\ArcGIS10.1\python.exe right now. If it won't import arcpy, then you'll need to do the reinstallation first. But python.exe will live in C:\Python27\ArcGIS10.1\, not C:\Python27\ after you've installed ArcGIS.
ToddJackson2
Hi Trevor,
As Jason said, the existence of both python installations is the most likely cause of the issue.  What you could try doing before attempting a reinstall of ArcGIS is set some python directories in your PATH to see if that solves the problem
To set your PATH variable in Windows, go to Start >> Control Panel >> System, click Advanced System Settings, click the Environment Variables button in the lower part of the Advanced tab.
In the System variables section in the lower part of the form, scroll through until you find the Path variable.
Make sure that there are no values pointing to the C:\Python27 directory, if so delete those parts (between the semi colons).  Add the following to the end of your Path variable -
C:\Python27\ArcGIS10.2\;C:\Python27\ArcGIS10.2\Scripts\
This should be enough to allow calls to python to use the ArcGIS embedded python instance by default.
I notice one exception you are seeing is coming from the PyWin module.  It may have also been affected by the two python installations.  Try installing PyWin32 again, and make sure during the installation that it finds the ArcGIS embedded python environment to install into.
Cheers,
Todd
