cannot add the shapefile into arcgis
3782
10-20-2014 09:57 PM
JINGYALIANG
My friend renamed the shapefile's name in windows 7 system, but not in the catelog. When he noticed that it is a fault, he changed the all related files' names into the original ones in catelog environment. And then, it happened error. It cannot add into arcgis and it noticed that "Number of shapes does not match number of table records". How can we deal with this issue? Thank you very much.
ChrisDonohue__GISP
It might be possible to recover the shapefile by using the "Previous Versions" function in Windows 7.  However, read the cautions below before trying this:
1.  Use Windows Explorer to browse to the file.
2.  Right-click on the File, then pick"Properties".
3.  Choose the "Previous Versions" Tab.
4.  Look to see if a previous version is listed.  If there is a version, you can potentially restore it with the Restore function in this window.
-----CAUTIONS:
1.  Because this process will overwrite data, it is best to back up the information to a different location first so you can fall back on the backup copy if the restore goes awry.  Once you restore, it can't be undone.
2.  You will need to restore all the components of the shapefile.  At minimum, this will include files with the extension .shp, .shx, and .dbf.  There may be other files with different extensions also.  See this link for ideas on what other extensions may be present:
http://en.wikipedia.org/wiki/Shapefile
3.  If the shapefile is in a folder, one strategy to have all the shapefile components restored at once is the restore the folder instead of the individual files.  However, consideration will have to be made for all other data and folders that may be in this folder (and files and folders off those), as they too will be affected by the restore.
Hope this helps,
Christopher Donohue, GISP
DanPatterson_Retired
did you search that phrase in GeoNet?  Is the spelling and text case for all the renamed files the same?  is he sure that a row wasn't deleted in the shapefile's table? are all the parts that make up the shapefile there (ie *.shp, *.shx, *.dbf etc )
JINGYALIANG
I am very sorry, I am not sure that. But he said he didnot change anything just renamed the file.
ChrisDonohue__GISP
-----CAUTIONS:
Hope this helps,
JINGYALIANG
Hi, Chris:
Thanks so much for your help. Done!
