Can I call a rule, then return to the previous one and continue it? Or call a cga within a cga?
2006
7
10-16-2014 08:23 AM
LR
Occasional Contributor III
For example like this, to produce a red 10m tall block. The script is very simplified, just to show the general idea.. I can't just pack the function into Lot.
Lot -->
ColorScript
extrude(10)
ColorScript -->
color(1,0,0)
Also is it somehow possible to call another cga within a cga file? For example, I have one function (coloring) I need to execute on every building and that function doesn't change. It's also rather big and gets in the way because I can't collapse it. Another case would be the roof construction parts, or texturing parts. So what I basically want to do is something like
Lot -->
extrude (10)
ColorScript.cga
is that possible somehow?
by Anonymous User
Not applicable
Add this line to your first CGA rule:
import ColorScript: "rules/ColorScript.cga" #(Or whatever the path to the imported cga file is)
Then your code will work as in your second example:
Lot -->
extrude (10
ColorScript.colorMe
This sends the extruded mass into a rule called "colorMe" in your rule ColorScript.cga.
This importing can go more than one level deep.
LR
Thanks!
However there's one problem, I can't get the loading to work dynamically. What I'm trying to do is create a base script that calls other scripts based on their gid for each building. It works manually, but when I try to create the path with variables, it doesn't (mismatched token). The same method works for textures, though.
I figured if this works, I could use the same method to "switch back" from the second script to the first..
version "2014.0"
attr gid = 0
attr gidpath = "rules/"+gid+".cga"
import gid_switch: "rules/628071.cga"  //works, gid of shape
import gid_switch2 : gidpath // doesn't work
import gid_switch2 : "rules/"+gid+".cga" // doesn't work
//test for constructed path for textures, works
attr path = "images/"+gid+"/"
attr end = ".jpg"
Lot -->
  texture(path+"chickens"+end)
  alignScopeToGeometry(zUp, 0, world.lowest)
  setupProjection(0, scope.xy, 0.3, 0.3)
  projectUV(0)
gid_switch.Lot //just a color command
by Anonymous User
Not applicable
This can't be done this way... No dynamic CGA importing.
MatthiasBuehler
This is the only way of getting 'back' to the first rule:
rule1.cga:
import rule2: "rule2.cga"
Shape -->
    rule2.DoExtrude
rule2.Mass -->
    color(1,0,0)
rule2.cga:
DoExtrude -->
    extrude(10)
    Mass // notice this is an UNUSED RULE with a yellow warning
this should result in a red extruded shape.
ok ?
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
by Anonymous User
Not applicable
Matt, he'd like to build the string for the name of the imported CGA file dynamically... see his 2nd question.
LR
Yep, otherwise it wouldn't be very useful in my situation. So could it be done in another way? With Python maybe?
Even something like this would be ok, creating the list wouldn't be too hard with Excel:
ThisDoesntWork-->
case gid == 628071: import gid_switch: "rules/628071.cga"
case gid == 628072: import gid_switch: "rules/628072.cga"
case gid == 999: color(0,1,0)
else: color (1,0,1)
MatthiasBuehler
Hi ..
no, there's no other syntax in CGA to do this.
sorry.
I wished for this also a loooong time.
e.g.
attr number = 1
Shape -->
    eval("Rule" + str(number))
Rule1 -->
    Continue.
Matthias Buehler
twitter: @MattB3D
