How to Explode Multipart Feature
15408
8
10-13-2014 07:23 PM
BenVan_Kesteren1
I am just wondering if anyone knows how to explode a multipart feature? I have a line that has two parts that are separated geographically, and now I want two separate lines in my table. There is the button in ArcMap but I cannot find it in ArcGIS Pro Prerelease.
Anyone done this before?
ChristopherBrown4
HI Ben,
I had a quick look, and if you want ALL multipart features in your current feature class to be single part there is a Toolbox Tool. But as you say in the Prerelease at least there does not seem to be all of the Advanced Editing Tools that we are used to seeing in ArcMap.
I hope this helps,
CDB
BenVan_Kesteren1
Hi Christopher, thanks for your reply. im glad it someone else has had a look and couldnt see it. I thought it would be an obvious one to find, it seems not.
Thanks again.
by Anonymous User
Not applicable
Ben,
The Editor's explode command isn't implemented yet. You can use the GP tool in the meantime.
BrianWade
GP Tool? in ArcGISPro, where that located?
as far as I can see there's no way to explode in Pro
Brian
DanPatterson_Retired
That's because it isn't call Explode it is... Multipart To Singlepart—Data Management toolbox | ArcGIS for Desktop
BrianWade
Thanks Dan
I saw that, but assumed based on the Title, it was taking a multi part and creating a single part, which on thinking thru a bit on my part would be simpler if just using merge. Optimally I would like to explode while editing like the explode tool in advanced editing in Arc10.3 but this will work, I just don’t need it to write out to a new feature layer, I need it to be a temp explode while editing features in Pro, I’m re-merging quickly a few edits later...
Thanks for the quick tips
Brian
by Anonymous User
Not applicable
The editor's explode command will make a return in Pro 1.2 (Soon).
You can also try the explode developer sample for Pro 1.1. This sample doesn't support dounut polygons, the core command will.
DEAF_PROBERT_68
Honored Contributor
or you could go to the attribute table and select the ones you don't want and delete it . Would that work for you ?
