Display text unless null, if null display text of next attribute colum
2289
10-10-2014 02:33 PM
RickeyFight
I have trail data.
I want to show map tips if the trail has a name.
Unfortunately, I cannot change the data. I want the Name to be displayed. If Name is Null then displayed the Group_ field if not the group then Route_2 and if not Route_2 then Route_1
My code right now looks like this:
dojo.connect(Layer, "onMouseMove", function (evt) {
                    if (evt.graphic) {
                        if (evt.graphic.attributes) {
                            ShowMapTip(evt, "<b>Name</b>: " + evt.graphic.attributes.NAME );
                dojo.connect(Layer, "onMouseOut", CloseMapTip);
Any suggestions would be greatly appreciated!
SteveCole
Honored Contributor
Maybe there's an issue with your fields being blank vs NULL; hard to say from my end on the outside. Let's try evaluating your field values another way, Let's look at the length of the field's value.:
                            var theString;
                            if(evt.graphic.attributes.NAME.length > 0) {
                                 theString = "<b>Name1</b>: " + evt.graphic.attributes.NAME;
                            } else if (evt.graphic.attributes.GROUP_.length > 0) {
                                 theString = "<b>Name2</b>: " + evt.graphic.attributes.GROUP_;
                           } else if (evt.graphic.attributes.ROUTE_2.length > 0) {
                                 theString = "<b>Name3</b>: " + evt.graphic.attributes.ROUTE_2;
                           }  else {
                                theString = "<b>Name4</b>: " + evt.graphic.attributes.ROUTE_1;
                            ShowMapTip(evt, theString);
SteveCole
Honored Contributor
How about something like....
                            var theString;
                            if(!evt.graphic.attributes.NAME) {
                                 theString = "<b>Name</b>: " + evt.graphic.attributes.NAME;
                            } else if (!evt.graphic.attributes.GROUP_) {
                                 theString = "<b>Name</b>: " + evt.graphic.attributes.GROUP_;
                           } else if (!evt.graphic.attributes.ROUTE_2) {
                                 theString = "<b>Name</b>: " + evt.graphic.attributes.ROUTE_2;
                           }  else {
                                theString = "<b>Name</b>: " + evt.graphic.attributes.ROUTE_1;
RickeyFight
Thank you for the quick response!
I changed the code slightly (bold numbers) to see why it was not working correctly. The trails with NAME's displayed with a label of Name4. Every other trail had a label of Name4 but nothing after that. I am not sure why it is pull the label of the last option.
                            var theString;
                           }  else {
SteveCole
Honored Contributor
                            var theString;
                           }  else {
RickeyFight
Thank you!
The only thing i changed was the 0 to 1 and it worked! (in bold below)
                            var theString;
                            if(evt.graphic.attributes.NAME.length > 1) {
                            } else if (evt.graphic.attributes.GROUP_.length > 1) {
                           } else if (evt.graphic.attributes.ROUTE_2.length > 1) {
                           }  else {
