Widget Preload
5798
10-07-2014 11:05 AM
KeisukeNozaki
Would it be possible to set widget preloaded?
For ArcGIS Viewer for Flex, all I need is preload="open" in config.xml.
I see something similar in config.json.
Thank you for your advice.
Keisuke
RobertScheitlin__GISP
Keisuke,
   See this thread: Open widget at startup
KeisukeNozaki
Robert,
Where can I find optional tags like "openAtStart"?
I checked Web AppBuilder Help and ArcGIS web map JSON format but have not found yet.
Thank you.
Keisuke
Keisuke,
  No the WAB is still in beta/pre-release and thus the documentation is incomplete
LarryStout
It's buried, but openAtStart is documented in two places in Beta2:
<beta 2 folder>\client\stemapp\config-readme.text
file:///<beta2 folder>/docs/index.html#/Open_a_widget_at_app_start/03w300000003000000/
