Tutorial 3: Map Control - Bug within New Map Layer > Mapping
3078
10-06-2014 03:17 AM
LisaStähli
Hi there!
I am new to City Engine and started to work with the tutorials offered by ESRI. At the moment I stuck at tutorial 3 at step "skyline map". I tried to create a New Map Layer > Mapping, connected to the right png-File as Mapping file, filled in all the correct numbers for bounds, but I am not capable of adding a row to Mappings.
Whenever I add a new row and start typing something into one of the fields (Attribute / Channel / Minimum / Maximum), the row mistierioulsy disappears. It doesn't matter which field I try to fill in.
I am not sure if there is anybody here stil working on the tutorials and can eventually help me in this case. If not, I would consider it is a bug that only the IT-service at ESRI's can fix, right?
Thanks for any help!
Lisa
Link to Tutorial: http://resources.arcgis.com/en/help/cityengine/10.2/index.html#/Tutorial_3_Map_control/02w10000000t0...
LisaStähli
Problem solved... if you make the window bigger, the rows suddenly "reappear". Sorry for bothering .
