Customize an embeded web map
1693
10-01-2014 02:59 PM
ChristianSmith
I am using the following code to embed a web map on a web page. I would like to customize the banner color and maybe play with some of the text fonts etc. Is there a way to customize the embeded map styles?
<div class="col col1_1" align="Center">
                <iframe width="500" height="400" frameborder="0" scrolling="no" marginheight="0" marginwidth="0" src="http://tpl.maps.arcgis.com/home/webmap/templates/OnePane/basicviewer/embed.html?webmap=c9729a84beee4..."></iframe>
                </p>
                <small>
                <a href="http://tpl.maps.arcgis.com/home/webmap/viewer.html?webmap=c9729a84beee4ded9bd61f2b61598e0c&extent=-1..." style="color:#0000FF;text-align:left" target="_blank">View larger map</a>
                </small>
            </div>
KellyHutchins
Esri Notable Contributor
Hi Christian,
In the iframe code does the url include OnePane/basicviewer? If so then you can't customize the font but you can choose from a set of pre-defined color themes. The available colors are orange, green, blue, gray and purple. To change the color you'll need to add a theme parameter to the url. Here's an example that shows the green theme.
src="http://jsapi.maps.arcgis.com/home/webmap/templates/OnePane/basicviewer/embed.html?webmap=106d8ef38ae..."
KellyHutchins
Hi Christian,
