Varianble Name function
6868
10
09-24-2014 11:54 PM
MittRamgobin
Is there a function that returns the name of the variable rather than its contents.
For example.
T = 1
R= 2
S= 3
P = (T, R, S)
Is there a fucntion that if I do function(T) it will return T?
Tags (1)
curtvprice
Please see Posting Code blocks in the new GeoNet
Suggested change, use a list, and create a list of labels in the same order:
Transmission = [T330OH, T330UG, T220OV, T132OH, T132UG, T66OV, T66UG, T33OH, T33UG, TransStruc, Substation]
TransLabels = ["T330OH", "T330UG", "T220OV", "T132OH"  (etc)
Then at the end:
k = 0
for Struc in Transmission:
    outputPath = r"S:\SupportServices\LGAShapefiles"
    basefileName = str(LGA2)+str(Struc))
    fileFormat= '.shp'
    finalDest = os.path.join(outputPath,basefileName+Translabels + fileFormat)
    arcpy.Clip_analysis(Struc,"LGAlyr", finalDest)
    k += 1
print "Process ended"
An unrelated comment, you seem to be using ListFeatureClasses (which returns a list) when you really want a path to a single dataset:
maybe instead of
T330OH = arcpy.ListFeatureClasses("GISTRAN.Trans_330kV_OH_Carrier","All","GISTRAN.Transmission")
you mean:
T330OH = os.path.join("GISTRAN.Transmission", "GISTRAN.Trans_330kV_OH_Carrier")
curtvprice
Can you explain what you are trying to do?
What do you do after P = (T,R,S)?
P[0] and P[T-1] will both return 1.
eval("T") will also return 1.
MittRamgobin
I want to loop through P and then return T R S, not 1 2 3
e.g
for x in P
filename = " XYZ " + T
The desired output is XYZT not XYZ1
Is that possible?
curtvprice
You could create another list:
P1 = ["T","R","S"]
filename = "XYZ" + P1[0]
Or maybe a dictionary?
D = {1:"T", 2: "R", 3: "S"}
D[1] is "T"
if T == 1, D is "T"
MittRamgobin
import arcpy
import sys
import os
# Script to create LGA Map with WP Infrastructure
# Define variables
arcpy.env.workspace = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\DynamicCredentials@GISR.sde"
#LGA = arcpy.GetParameterAsText(0) # Input Required Local Government Area
LGA ="COOROW, SHIRE OF"
LGA2 = "COOROW"
#Define Layers to Intersect
#1. Transmission Layers
T330UG = arcpy.ListFeatureClasses("GISTRAN.Trans_330kV_UG_Cable","All","GISTRAN.Transmission")
T220OV = arcpy.ListFeatureClasses("GISTRAN.Trans_220kV_OH_Carrier","All","GISTRAN.Transmission")
T132OH = r"C:\Users\N041871\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\DynamicCredentials@GISR.sde\GISTRAN.Transmission\GISTRAN.Trans_132kV_OH_Carrier"
T132UG = arcpy.ListFeatureClasses("GISTRAN.Trans_132kV_UG_Cable","All","GISTRAN.Transmission")
T66OV = arcpy.ListFeatureClasses("GISTRAN.Trans_66kV_OH_Carrier","All","GISTRAN.Transmission")
T66UG = arcpy.ListFeatureClasses("GISTRAN.Trans_66kV_UG_Cable","All","GISTRAN.Transmission")
T33OH = arcpy.ListFeatureClasses("GISTRAN.Trans_33kV_OH_Carrier","All","GISTRAN.Transmission")
T33UG = arcpy.ListFeatureClasses("GISTRAN.Trans_33kV_UG_Cable","All","GISTRAN.Transmission")
TransStruc = arcpy.ListFeatureClasses("GISTRAN.Trans_Structure","All","GISTRAN.Transmission")
Substation = arcpy.ListFeatureClasses("GISTRAN.Substation","All","GISTRAN.Transmission")
#Group Transmission Values:
Transmission = (T330OH, T330UG, T220OV, T132OH, T132UG, T66OV, T66UG, T33OH, T33UG, TransStruc, Substation)
#Select Required LGA
arcpy.MakeFeatureLayer_management("GISEXT.Local_Government_Authority", "LGAlyr")
fieldName = "NAME"
Query = "\""+fieldName+"\"='"+LGA+"'"
arcpy.SelectLayerByAttribute_management ("LGAlyr", "NEW_SELECTION", Query)
###arcpy.SelectLayerByAttribute_management ("LGAlyr", "NEW_SELECTION", """ "NAME" = 'ALBANY, CITY OF' """) - working code
fileFormat= '.shp'
finalDest = os.path.join(outputPath,basefileName+fileFormat)
#print Struc
arcpy.Clip_analysis(T132OH, "LGAlyr",finalDest)
#arcpy.Clip_analysis(Struc,"LGAlyr", finalDest)
That is my code.
In the last loop I want to use the variable name to name the output file and the variable content for geoprocessing....
Is that possible?
curtvprice
Then at the end:
k = 0
    fileFormat= '.shp'
    k += 1
maybe instead of
you mean:
MittRamgobin
Thank you Curtis.
That worked and yes if did figure the path thing.
MittRamgobin
I have another issue. I want to delete all empty shapefiles in a folder. The following is not working:
#Find empty shapefiles and delete them
arcpy.env.workspace = r"S:\SupportServices\LGAShapefiles"
shapefiles = arcpy.ListFeatureClasses()
for shapefile in shapefiles:
    if arcpy.management.GetCount(shapefile)[0]=="0":
        arcpy.Delete_management(shapefile)
        print shapefile + "Deleted"
curtvprice
GetCount doesn't return a number, it returns a result object. This is documented in the help for the tool.
Try:
if str(arcpy.management.GetCount(shapefile))=="0":
# or (both will work)
if arcpy.management.GetCount(shapefile).getOutput(0)=="0":
MittRamgobin
Still not working.
ERROR 000732: Input Rows: Dataset GISTRAN.SubstationCOOROW, SHIRE OF.shp does not exist or is not supported
Failed to execute (GetCount).
