Duplicate Values
2240
5
09-19-2014 10:08 AM
RickWarner
I have a table that has one field with duplicate values. Is there any code that will label the duplicates 0, 1, 2, 3, 4 ..., rather than 0 and 1 as the following code does which I've found on ESRI's web site.
Python parser, and use  then use the following codebook.
uniqueList = []
def isDuplicate(inValue):
  if inValue in uniqueList:
    return 1
  else:
    uniqueList.append(inValue)
    return 0
isDuplicate(!PCN!)
Tags (1)
BrianCarson2
uniqueList={}
    global uniqueList
    if inValue in uniqueList.keys():
        uniqueList[inValue] += 1
        return uniqueList[inValue]
    else:
        uniqueList[inValue] = 0
Using the Python Parser, insert the following into the code block.
This will perform the same operation as the above, but will increment the duplicate records as 0, 1, 2, 3 ... and then revert to 0 when it hits the next unique value.
At the end you would then use the isDuplicate(!<Your Field Name>!)
forestknutsen1
I am not sure I understand. You are saying that you have a field that has values like 1,2,2,3,4,4,5 etc. and you want 1,2,3,4,5,6 what is the value of this. Why not just use the OID if you need a UID (unique identifier). If this will not work-  what you want can be done with python using an UpdateCursor: here is info on it.
ArcGIS Help 10.1
then just update the row with a count variable. and increment it each time though the loop. count += 1 i.e. count = count + 1
BrianCarson2
uniqueList={}
    global uniqueList
    else:
RickWarner
Brian, thank you so much, it worked perfectly.
DanPatterson_Retired
this thread still remains open, if a solution was provided please select the correct answer to finalize the discussion
RickWarner
This best answer which worked perfectly was by B Carslon.
Thanks so much…
