Zoom to layer
2744
09-18-2014 12:21 AM
Yaron_YosefCohen
Occasional Contributor II
I have a problem with the getExtent function on  arcpy
I try to focus on  layers that start with letters "ra" and then sets the scale of 50000. i try to use asterisk (*) but the code does not work
import arcpy, os, sys
from arcpy import env
env.workspace = r"C:\Project"
for mxdname in arcpy.ListFiles("*.mxd"):
    print mxdname
    mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname)
    df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
    lyr = arcpy.mapping.ListLayers(mxd, "*ra", df)[0]
    ext = lyr.getExtent()
    df.extent = ext
    print 'getExtent'
    df.scale = 50000
    print 'scale'
    mxd.save()
del mxd
Any help will be appreciated.
DanPatterson_Retired
starts with would be "ra*"  you have ends with "*ra"  see the listlayers menu example
Yaron_YosefCohen
it don't work.
    print mxdname
    lyr = arcpy.mapping.ListLayers(mxd, "r*", df)[0]
    df.extent = ext
    print 'getExtent'
    mxd.save()
del mxd
Then the question is...did you get an error messages? What do you want listlayers within the for loop? it will return a list object and you can't get the extent of a list only individual layers.
Yaron_YosefCohen
i want arcpy zoom to 2 lyr then get scale of 50k
