erro when creating button with Arcgis python add-inn
3951
5
09-18-2014 10:04 AM
GustavoCordero
New Contributor III
PaulCrickard1
Occasional Contributor II
What does your config.xml look like. Here is a portion of mine - note the button id showing up in the toolbar too.
    <Commands>
        <Button caption="PaulButton" category="PaulAddinPython" class="PaulButtonClass" id="PaulPythonButtonToolFile.button" image="Images\1.PNG" message="Hello Dude" tip="Writes Hi"><Help heading="Hep Heading Stuff">The contents of help</Help></Button>
        </Commands>
    <Extensions>
        </Extensions>
    <Toolbars>
        <Toolbar caption="PaulToolbar" category="PaulAddinPython" id="PythonAddIns_addin.PaulPythonToolbar" showInitially="true"><Items><Button refID="PaulPythonButtonToolFile.button" /></Items></Toolbar>
        </Toolbars>
    <Menus>
        </Menus>
    </ArcMap></AddIn></ESRI.Configuration>
GustavoCordero
New Contributor III
my button, zooms to a selected layer
PaulCrickard1
But does your config have a toolbar that points to the button by id? if not, then the button will not show up on the toolbar.
You need to check your config and see if you have a button and toolbar and that the two are connected.
GustavoCordero
New Contributor III
and where I can see this in the wizard?
PaulCrickard1
Wherever you put the source files.
