vb.net arcobjects run "Summary Statistics" GeoProcessing tool
3205
5
09-18-2014 02:01 AM
LiYao
Hello all,
I am now trying to use vb.net to run "Summary Statistics" GeoProcessing tool. The corresponding parameters in the "Summary Statistics" GeoProcessing is as follows:
The vb.net code:
Dim GP As GeoProcessor = New GeoProcessor()
        Dim parameters As IVariantArray = New VarArray
        parameters.Add("geri_db.DBO.BQ_Segment_1")
        parameters.Add("C:\Users\lyao\Documents\ArcGIS\Default.gdb\BQ_Segment_1_Statistics1")
        parameters.Add("geri_db.DBO.BQ_Segment_1.OBJECTID")
        parameters.Add("MAX")
        GP.Execute("Summary_Statistics_analysis", parameters, Nothing)
ShriramBhutada1
Hi Li,
Yeah there was small error. Following code work. I've tested in on my computer.
Hope this is helpful.
Shriram
Program
private IGeoProcessorResult2 gpr = null;
static void Main(string[] args)
RuntimeManager.Bind(ProductCode.Desktop);
GeoProcessor gp =new  GeoProcessor();
IVariantArray parameters = new VarArrayClass();
@"C:\junk\122.mdb\test");
@"C:\\Users\\shri7493\\Documents\\ArcGIS\\Default.gdb\\TBL_HYDRANT_Statistics");
"OBJECTID MAX");
IGeoProcessorResult gpResult = gp.Execute("Statistics_analysis", parameters, null);
for (int i = 0; i < gpResult.MessageCount; i++)
Console.Write (gpResult.GetMessage(i).ToString());
LiYao
Don't know why part of the contents not displayed.
I want to know:
(1) is there any parameters missed in vb.net code?
(2) The sample from ESRI uses buffer GP:
gp.Execute("Buffer_analysis", parameters, Nothing)
But I use summary statistics_analysis, Summary_Statistics_analysis, Summary Statistics_analysis, SummaryStatistics_analysis, all of them not work.
Can please advise me on it? thanks a lot!
ShriramBhutada1
Hi Li,
Try following code and see if it works.
        parameters.Add("geri_db.DBO.BQ_Segment_1.OBJECTID MAX")
LiYao
Hi Shriram,
Thank you very much for the reply. But it still not work.
ShriramBhutada1
Hi Li,
Shriram
Program
"OBJECTID MAX");
LiYao
Hi Shriram,
Thank ypu very much for the patient and help.
