Overlapping Points when geocoding
4492
09-18-2014 01:51 PM
WilliamRice1
I am geocoding a large dataset of businesses within a city. There are a handful of locations that have duplicate addresses but are not the same business. Is there a way that I can get overlapping points to offset next to each other? Or is there some other process I can do in order to show these points next to each other without manually seleting and moving each point one by one?
Any advice or suggestion is appreciated.
-William
AnthonyGiles
Honored Contributor
have a look at the tool called "Disperse Markers" under Cartography Tools > Cartographic Refinement
ArcGIS Desktop
WilliamRice1
Is there a specific license or version needed to use the cartographic refinement tool? I only have calc line caps and polygon main angle available.
Also, I have a standard license and using 10.1, if that makes a difference.
AnthonyGiles
Honored Contributor
Yes you need an advanced licence.
there is a possible solution using labels on this thread:
Clustering Point Features using ArcMap 10.1
