read file GDB using python
18579
09-14-2014 10:56 AM
Gisbert61
Hi, how do I read geodatabase content using python? Creating a file geodatabase is not a problem but after that, how can I acces the file GDB using python and -for example- lists its content
tia, Bert
DanPatterson_Retired
Do you mean like ListFeatureClasses ?  There are many more here if this is what you mean
Gisbert61
That's exactly what I mean, thanks Dan, and thank you Matthew for your code example.
MatthewLewis
just adding to the first reply
import arcpy
from arcpy import env
env.workspace = "C:/mygdb.gdb"
fclist = arcpy.ListFeatureClasses()
for fc in fclist:
     ## Add Code here
     print fc
