vb.net arcobjects determine new create feature geometry
5326
12
09-14-2014 07:44 PM
LiYao
Dear all,
I want to check whether I can determine the geometry type of the new created feature, is it a point, polyline or polygon?
I am using vb.net and arcmap 10.2.1, thanks.
FrankHellwich1
so you're looking for a way to run code each time a new feature is created in an edit-session ?  This can be done by using Editor-events (see "ArcGIS Desktop editing for developers" in the online help): the editor object that handles editing tasks in ArcMap owns an event "OnCreateFeature" where you can react on new features inserted by the user.
I hope this helps you and meets your needs. Otherwise please give some more informations about the workflow you want to support.
Frank
FrankHellwich1
you could check the GeometryType of the Shape-property of IFeature:
     IFeature feature = CreateFeatureOfUnknownType();
     //do some null-checks here
     //then
     switch(feature.Shape.GeometryType)
          case ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon:
               //blah
               break;
          case ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline:
               //blahblah
               break;
          //etc
LiYao
Thank you Frank for the quick reply.
I convert the code you provided to vb.net and insert into my vb.net project.
But I get an error:
'CreateFeatureOfUnknownType' is not declared. Is there any library need to import?
FrankHellwich1
Sorry - "CreateFeatureOfUnknownType" is no existing function, it's a placeholder in this example for the function you are using to create your feature.
LiYao
Hi Frank,
I am creating feature in arcmap, not arcobjects.
FrankHellwich1
Frank
LiYao
Hi Frank,
Thanks for the update. Yes I am looking for a way  to run code each time a new feature is created in an edit-session. Will follow the instruction you give me.
LiYao
Hi Frank,
Sorry to trouble you. I have followed the sample code from : http://resources.esri.com/help/9.3/arcgisengine/arcobjects/esriEditor/IEditEvents_OnCreateFeature.ht...
I can determine when the new feature is created, but I don't know how to get the geometry type, any hints? So sorry I know little about arcobjects.
FrankHellwich1
Hi Li,
no problem. In the event-handler OnCreateFeature you receive the parameter "obj" of type IObject. IFeature inherites from IObject - in this case the parameter obj is an IFeature so that you can cast obj to IFeature and use the code above to check the GeometryType.
I'm no vb-crack but I guess it should look like this (at least similar):
Private Sub OnCreateFeature(ByVal obj As ESRI.ArcGIS.Geodatabase.IObject)
   Dim feature as IFeature
   feature = DirectCast(obj, IFeature)
   if feature.Shape.GeometryType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon then
      'do something with a polygonfeature
   else etc.
 End Sub
regards
Frank
LiYao
Thanks Frank, it works.
