X-Ray for ArcCatalog Import Error
5131
09-12-2014 03:52 PM
TrentReeder
I keep receiving this error when trying to import an updated xml file to a selected database:
"XML error on line 1, position 2431.  Whitespace is not allowed at this location."
I get this error after updating the spatial reference and then saving the xml file.  I do not get this error when I import an xml file that has not been saved after updating the spatial reference.  I have tried the importing process both in SDE and a FGDB and still receive the import error.  Comparing the saved xml file to the original file, for which I have no troubles importing, I noticed the saved version has whitespace between tags while the non-altered xml file does not have whitespaces.
Here's my setup:
ArcGIS Desktop 10.2.2
X-Ray for ArcCatalog 10.2
Windows 7 Enterprise SP1
Thanks for any thoughts!
AsrujitSengupta
Regular Contributor III
You could be hitting a known bug which was very recently logged.
Can you please confirm which XML file you are observing this issue with?
BUG-000080891- Gas Data Model XML workspace returns the error, "XML Import Error: XML error on line 1, position 2431. Whitespace is not allowed at this location” when trying to import into a file geodatabase after a new spatial reference is assigned using the X-Ray for Geodatabases tool.
The workaround as you have already observed is:
Manually assign the spatial reference. Do not apply a new spatial reference before importing.
AsrujitSengupta
TrentReeder
Yes, it's the Gas Data Model.  Bummer, looks like I better start the manual process.  Thanks for the reply though!
