Python toolbox: how to set default values
8406
5
09-11-2014 08:01 AM
AlbertoLaurenti
I need to set a default value for a Boolean parameter in my Python toolbox, but I didn't found any documentation about that. I'm able to do it using the custom toolbox wizard, but I found nothing on how to do the same in a python toolbox.
Any idea?
AlexanderNohe1
Honored Contributor
Here is a small sample of adding a boolean value and adding a default value to it.
        booleanTest = arcpy.Parameter(
            displayName="boolTest",
            name="booleanTest",
            datatype="GPBoolean",
            parameterType="Optional",
            direction="Input")
        booleanTest.value = "true"
Does this help?
AlexanderNohe1
Honored Contributor
            name="booleanTest",
            direction="Input")
Does this help?
AlbertoLaurenti
Thanks Alexander, it works perfectly!
DanPatterson_Retired
Why not do it through the interface?  For example, you can right click on a toolbox script and access its properties etc, then bring up the dialog which allows you to establish the relationship etc between your input parameters and the script.  This image is a visual of establishing a Folder as an input parameter.
AlexanderNohe1
Honored Contributor
Hi Dan,
I don't think that functionality is available with python toolboxes but rather script tools only.
Thanks Alexander ... never mind ...
