Re-projecting XYZ Values
4447
09-11-2014 06:49 AM
SeanMcDade
I have a question relating to converting XYZ values from one projection system to another.
If I have a grid of XYZ points in one projection system where
X = Easting
Y = Northing
Z = Elevation
and I convert them to another projection system, should my Z values change as well as my X and Y values or should they stay the same? It seems to me that the Z values should stay the same but I could be wrong.
Sean.
MelitaKennedy
Esri Notable Contributor
Currently they will stay the same because we aren't projecting vertical data yet. Even when we do, as long as the vertical coordinate system stays the same, the Z values should be unchanged.
Melita
Mohamed_MagdyMohamed_Hussain
That is depend on the transformation parameters you used. usually there are three parameter for transformation called translation parameters (X, Y, Z) if Z have value there are different in Z will be observe but if delta Z is 0 there are no change in Z Value.
But there are another case if the transformation parameters are 7 parameters as:
- 3 parameters translation (dX, dY, dZ)
- 3 parameters rotation (rX, rY, rZ)
- 1 parameter for Scale factor
in this case with 7 parameters the Z value must be changed even dZ is zero
all above for ellipsoidal elevation which observed directly by GPS or ASTER, STRM DEM and that is different about the MSL (Mean Sea Level) elevation
Mohamed
