ERROR 010429:Error in GRID IO: S_VXfer: Read error.
7610
5
09-10-2014 04:14 AM
JessiecarEsguerra
Hi, I would like to create a Flow Direction using a Mosaic Dataset output. When trying to run the Fill process, I got the error messgae "ERROR 010429:Error in GRID IO: S_VXfer: Read error.". This error appeared when the percentage of completion is already in 99% which is very frustrating cause normally, when there is an error in Fill/Flow process, error occured right away or a few minutes but would not take about 40hrs running it and reaching 99%. Any input or suggestions on how to resolve this issue would be highly appreciated. Thanks!
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Try zooming into a small extent.  Then, open the Flow Direction tool and click on Environments > Processing Extent.  Set this to 'Same as Display'.  Execute the tool and see if it will create a flow direction raster for the small extent.
Also, what type of output raster are you trying to create (i.e. ESRI GRID, TIFF, IMG)?
JessiecarEsguerra
I am trying to create IMG. I tried the full extent and follow the settings you said but there still an error.
ERROR 999999: Error executing function.
The table was not found. [VAT_unified_flow]
("esri.Envelope") The operation was attempted on an empty geometry.
ERROR 010032: Unable to create the scratch grid c:\users\edm~1.use\appdata\local\temp\3\arc61d8\xx0217420000.
ERROR 010067: Error in executing grid expression.
Failed to execute (FlowDirection).
JessiecarEsguerra
Hi.. Anyone please who could provide inputs and suggestions on how to resolve said error? Thanks!
JessiecarEsguerra
Appreciate any inputs  guys in resolving error in creating fill/flow for big files of DEM. Thanks!
JakeSkinner
I would recommend logging an incident with Tech Support.  They will be able to trouble shoot this error and find you a solution.
