Installing the �??ArcGIS Web Applications Manager�?� require a separate instance,
3195
01-09-2013 12:47 AM
JamalNUMAN
Legendary Contributor
I�??m wondering why the installation of the �??ArcGIS Web Applications Manager�?� requires a separate instance. Previously, I could install it without the need to have a separate instance.
[ATTACH=CONFIG]20571[/ATTACH], [ATTACH=CONFIG]20572[/ATTACH]
What might be the issue?
Jamal Numan
by Anonymous User
Not applicable
Original User: pho
Hi Jamal,
At version 10.1, ArcGIS Server Manager is solely focused on hosting and administering services. It does not build web applications.
If you want to build a GIS web application without having to write code, you can use the ArcGIS Viewer for Flex or the ArcGIS Viewer for Silverlight. These now include interactive application builders that allow you to design a web app by pointing and clicking on the features you want, very similar to the way you built web apps with Manager in previous releases.
The ADF continues to ship with ArcGIS 10.1 for Server as a separate setup named ArcGIS Web Applications. This exists solely for the purpose of supporting legacy applications. The setup includes ArcGIS Web Applications Manager, a legacy version of Manager that allows you to view and modify your web applications.
More information can be found at the link below:
Migration to ArcGIS 10.1 for Server
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000002p0000000
JamalNUMAN
Hi Jamal,
Many thanks Phoebe for the answer.
In my point of view, I see that the �??ArcGIS Web Applications Manager�?� is much more powerful than the �??Flex�?� and �??silverlight�?� as it contains all the very basic functions.
[ATTACH=CONFIG]20616[/ATTACH]
Examples:
1. Find tool
2. Go to xy tool
Best
Jamal
Jamal Numan
JamalNUMAN
Hi Jamal,
So weird!
I uninstalled the �??ArcGIS web adaptor�?� and then installed the �??ArcGIS web aaplication�?� and it didn�??t require separate instance!
[ATTACH=CONFIG]20654[/ATTACH]
Best
Jamal
Jamal Numan
