Export to pdf problem
2598
03-10-2014 06:19 AM
by Anonymous User
Not applicable
Original User: minford
Good Morning. I have a stable mxd that is used for making property block key cards. Last week the export was working fine- this morning the export is adding a red background to the pdfs. I attached two pdf examples to this post that demonstrates the problem. Any advice on how to remove the red background from the export?
Thanks.
Rob
JimCousins
MVP Regular Contributor
Rob,
What has changed?
Do you see the red fill on screen, or only on export?
Have polygons been edited? Perhaps the geometry has been compromised - run repair geometry.
Are features selected, and your selection color is set to red?
Your output is Black and white in the one pdf, is your source all black and white, and the red fill is coming from nowhere?
Have you tried printing vs exporting to PDF?
If you export to image, does the red show?
Regards,
Jim
by Anonymous User
Not applicable
Original User: nidhinkn
Run Check Geometry tool on the data followed by Repair Geometry.
