Adding Attributes to Legend
7337
04-24-2014 07:55 AM
by Anonymous User
Not applicable
Original User: AmerMid
Hello, I am trying to find out if there is a way to add the sum of an attribute field to the legend. For example, I am wanting to show the sum of some acreage next to the symbol and name within the legend. Is there a simple way to do this?
JimCousins
Add the acreage sum to the attribute table, and then set the symbology to Categories >> Unique Values, many fields >> and choose the original field and the acreage field. Then the name and acreage will show in the legend.
Best Regards,
Jim
NealJander2
If it is a summarize operation, I would suggest doing a dissolve based on a field in the attribute table and then sum the areas. Then you can do what Jim Cousins‌ is recommending above.
