Create Direct Database Connection: SQL Server 2008
2414
05-16-2013 03:58 AM
PeterWilson
I've never had to connect to an enterprise database (SQL Server 2008) before and please note the database that I'm trying to connect to is not a spatial database. I want to connect to the following database to retrieve records that I can generate spatial data from. The records are of Police incidents that contain coordinates of the location of each incident and the particulars of the incident. I want to use the following information to start analyzing  crime.
I've been provided with the IP Address of the SQL Server (2008)  as well as a User Name and Password .
When I try to create a database connection from within ArcCatalog I receive the following error message:
I've attached a print screen of the database connection parameters that I'm entering as well as the error message.
I have asked the Database Administrator to change the compatibility of the particular database that I'm trying to connect to (IMSWarehouse) to level 90 (SQL Server 2005), but I still receive the same error.
Any advice in how I can create a direct connection to the following database will be appreciated.
Regards
NB: I'm currently running ArcGIS 10.1 with SP1
VinceAngelo
Esri Esteemed Contributor
You're probably looking for an ODBC or other pure database connection.  Direct Connect
will only work against databases with an ArcSDE geodatabase install.
- V
by Anonymous User
Not applicable
Original User: asrujit
Peter,
Please download and install a current SQL Server Native Client and then the connection should work fine.
Microsoft® SQL Server® 2008 R2 Feature Pack
http://www.microsoft.com/en-in/download/details.aspx?id=16978
Look for "Microsoft® SQL Server® 2008 R2 Native Client" under Install Instructions. Download and install that.
Hope this helps!
Regards,
