GDB multi patch / vertex colors
2787
05-14-2013 10:00 AM
nicholascarrington
Hello I'm  working  on a project where I'm trying to show solar potential in city engine see below...
Arc globe
[ATTACH=CONFIG]24300[/ATTACH]
CE 2012.1
[ATTACH=CONFIG]24301[/ATTACH]
The original files has this information and is stored in a geo-database (gdb). It works in ARC GIS (Arc Globe) but not in CE.
Can you point me to any information on this or is this a feature that is not yet implemented.
Thanks Again.
MatthiasBuehler1
Hi !
If you embed the information in textures, you can port the information.
If it's just colorized polygons in ArcGlobe, that is not supported.
Let me know..
M.
by Anonymous User
Not applicable
Original User: ncarrington
Thanks a lot Matt, yes it  was colored polygons. We found a quick work around using  ArcGIS > collada > 3dsmax> .obj > CE.
Avoiding that  part of the  .gdb. Look forward to seeing more native support in the  future  between  ArcGIS and CE.
Thanks for your reply.
by Anonymous User
Not applicable
Original User: matthiasbuehler
Hi !
You could also go ArcGIS > Collada > CE 😮
But be VERY cautious with georeferenced data ! Use a file format which handles the precision issues ( wobble effect ), e.g. use .kml.
Read this thread carefully :
http://forums.arcgis.com/threads/59442-FBX-export-%28models%29-to-3DSMAX
Ok ?
Matt
