Accessing the ???ArcGIS viewer for flex??? installed on the server machine,
3401
02-05-2013 11:15 AM
by Anonymous User
Not applicable
Original User: [email protected]
Accessing the �??ArcGIS viewer for flex�?� installed on the server machine,
The �??ArcGIS viewer for flex�?� is installed on the server machine (named P2). I tried to access it (from my machine named as P1) by typing http://P2/flexviewers but sounds not to work. I got the message below
[ATTACH=CONFIG]21463[/ATTACH], [ATTACH=CONFIG]21464[/ATTACH]
In return, I did the same thing in case of �??ArcGIS viewer for Silverlight�?� and it did work. I could access it using the url http://p2/builder/ but failed to deploy the application
[ATTACH=CONFIG]21465[/ATTACH], [ATTACH=CONFIG]21466[/ATTACH]
What might be the issue?
How one can build these application on the server machine (p2) while working from client machine (p1)?
Do I need to have IIS on the client machine (P1)?
Thank you
Best
Jamal
by Anonymous User
Not applicable
Original User: j.quinn
Try to unzip the supplied files into the C:\inetpub\wwwroot folder on your web server.
JamalNUMAN
Legendary Contributor
Many thanks Jonathan for the help,
These two files are already exist in that folder on the server machine (screenshot below)
[ATTACH=CONFIG]21474[/ATTACH]
What might be the issue then?
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Can you run Fiddler while accessing the FlexViewer app?  Does the Builder return any information about crossdomain.xml file not found, or something to that effect?
JamalNUMAN
Many thanks Jonathan for the prompt answer,
The screenshot below shows what I got from fiddler
[ATTACH=CONFIG]21512[/ATTACH]
How come the ArcGIS Web ADF and the Silverlight could be accessed with no problems while the issue is related to flex only
[ATTACH=CONFIG]21513[/ATTACH]
The web adaptor is installed
[ATTACH=CONFIG]21514[/ATTACH]
what might be wrong with the flex then?
Best
Jamal
Jamal Numan
