Direct Connect parameters for registering SDE database?
2235
02-01-2013 07:19 AM
by Anonymous User
Not applicable
Original User: Steve Clark
I am able to register our ArcSDE database on our ArcGIS Server by using the Create ArcSDE Connection File tool. But that appears (I think) to be an SDE connection. When I copy over a direct connection .sde file instead to the shareddata folder on the ArcGIS Server and import that file when registering, I get the "data item is inaccessible" error.
here's what the direct connection properties look like
[ATTACH=CONFIG]21324[/ATTACH]
I know this direct connection works on the 10.1 client but what are the parameters in the connection properties to make it work for registering an SDE database?
The ArcGIS Server 10.1 (with 64-bit Oracle) and ArcSDE and the 10.1 client are all on separate machines.
Additionally, ArcSDE is 10.0. Is that allowed (10.1 Server connecting to a 10.0 database)?
SteveClark
Ah, nevermind. Determined that the error and the reason why the server couldn't see the connection was that the server/services needed to be rebooted/restarted after 64-bit Oracle had been installed. It simply did not know about Oracle connections yet.
