How do I programmatically determine if a layer is versioned?
4433
11-01-2012 11:04 AM
GenaroGarcia
I need to determine if a layer is versioned or not programmatically.
Based on that, I need to set the editing option, "Edit a version of the database with the ability to undo or redo." to true (checked) or false (unchecked).
Is there a way to do this?
Any help is greatly appreciated.
by Anonymous User
Not applicable
Original User: sean_jones
Yes, use IEditProperties3.MultiuserEditSessionMode to switch  between versioned and non-versioned editing. This is the property behind that checkbox. This can only be set outside an edit session.
by Anonymous User
Not applicable
Genaro,
You can tell if an object is registered as version by using the members on IVersionedObject3
Also see this thread: : How to tell if feature class is registered with Move Edits To Base
You can set the versioning options (Editor options versioning tab) via the members on IEditProperties3
GenaroGarcia
Yes, that's what I needed to determine if the editing feature class is versioned or not.
Based on that, is there a way to set the edit session to versioned or not versioned.
I'm switching between layers, one versioned and the other is not.
by Anonymous User
Not applicable
