How do you Enable/Disable tool within a toolbar programmatically?
3114
10-25-2012 08:03 AM
GenaroGarcia
I have custom tools in a custom toolbar which one of them I need to disable when click on.
This tool invokes a custom entry form which I need to enable to tool when the form closes.
Is there a way to do this?
Any advice would be greatly appreciated.
RichWawrzonek
Genaro-
Is your custom toolbar an Add-In or a COM extension?
For an Add-In you need to add the OnUpdate() method to the main tool class:
protected override void OnUpdate()
            Enabled = true;   //Change this to evaluate a statement instead of always returning true
For a COM tool you add the Enabled() method:
public override bool Enabled
            get
                return true;   //Change this to evaluate a statement instead of always returning true
Note that these methods are continuously called by ArcMap so don't call any methods that take much time here. If your form is a singleton then you can simply do something like this:
Enabled = frmMyForm.OnlyInstance != null && frmMyForm.OnlyInstance.Visible;
RichWawrzonek
Genaro-
            get
