Checking line for missing sections - line topology?
1187
10-16-2012 05:40 AM
by Anonymous User
Not applicable
Original User: alnesbit
Hello all,
Hopefully this is an easy question, I just can't get my brain to think this morning. I'm using ArcEditor 10.1. I don't have a topology set up but I fear I have to go to that extent just to check these lines. I selected some lines in my overall line feature class and exported but it turns out I missed tiny sections of the line in certain places. So I had to go back and merge those little pieces into a larger line segment. Is there an easy tool where I can check if my selected line is contiguous? Or if it is missing pieces?
Thank you!
by Anonymous User
Not applicable
Original User: Hornbydd
Andrea,
Search the help file for "Finding dangles on line features".
Duncan
JohnSobetzer
Honored Contributor
A quick answer once you are in the middle of your selection process, is to switch the selection.  Depending on your data, missed sections should show up as bright blue letting you know you missed them.  Less simply, you can use your selection to create a temporary layer in the TOC, and then examine that for misses in various ways including symbology, but if it is fine export it to a new feature.
But if you are often finding this as a problem, and roads from public sources often have incredibly small sections, gaps, attribute errors, perhaps even overlaps, it might pay to process them ahead of time to make selection, symbology, analysis, etc. easier.  Setting up a topology to validate your roads may fix gaps under the tolerance, as would running an Integrate. As noted you could set it up to identify dangles.  Running the unsplit tool could get rid of all those little sections that share the same attribute but are unnecessarily split.  A planarize would get rid of overlaps and split lines where they meet.  You might need to explode features if you have multiparts.  Finding small sections with attribute errors is harder, you might try selecting for different attributes and then visually looking for those little blobs of blue, or focusing on segments of very small lengths.  If you have ETGeowizards there are several tools, including the pseudo nodes nodes and clean tools, that can fix things.
