Accessing Map service info?
1104
13
08-18-2010 07:37 AM
AndrewEgleton
New Contributor III
I'm trying to read the visible status of individual layers in a map service at start up so I can set if they are visible or not, but I am having no luck accessing the Map Service Info, here is my code:
 // Get indexes of visible layers
 AGSMapServiceInfo *dynaServiceInfo = self.dynamicLayer.mapServiceInfo;
 AGSMapServiceLayerInfo *dynaLayerInfo;
 NSMutableArray *visibleLayers = [NSMutableArray arrayWithCapacity:[dynaServiceInfo.layerInfos count]];
 for (int i = 0; i < [dynaServiceInfo.layerInfos count]; i++) {
  dynaLayerInfo = [dynaServiceInfo.layerInfos objectAtIndex:i];
  if (dynaLayerInfo.visible == YES) {
   [visibleLayers addObject:[[NSNumber alloc] initWithInt:i]];
My AGSMapServiceInfo object is always empty, but I'm not sure what I'm doing wrong. I've also tried directly accessing the layerInfos, and creating an array from them with no success either.
Any help appreciated.
Andy.
MarcoBrugna
Use this way:
AGSMapServiceInfo *serviceInfo = [[AGSMapServiceInfo alloc] initWithURLSynchronous:[NSURL URLWithString:aLayer.url]];
AGSDynamicMapServiceLayer *dynLayer = [[AGSDynamicMapServiceLayer alloc] initWithMapServiceInfo:serviceInfo];
so when you access to dynLayer.mapServiceInfo it will be not empty.
AndrewEgleton
New Contributor III
Thanks, that work perfectly!
I'm slowly getting my head around the iPhone SDK/Objective C, but its very different to C#!
KOLDODUARTE
Use this way:
In the new API 1.0 this is not works me, previusly with the Beta versions It is works perfectly, but now no, someone knows?
Thanks & Best Regards,
Koldo.
NimeshJarecha
The AGSMapServiceInfo::initWithURLSynchronous has been renamed to AGSMapServiceInfo::initWithURL:error:. Please refer Migration doc for detail of all changes.
You can refer ArcGIS Dynamic Map Service Layer doc as well.
Regards,
Nimesh
KOLDODUARTE
Regards,
Nimesh
Hi Nimesh,
I read all changes and I applied it, now I have this code, for example:
NSURL *url = [NSURL URLWithString: @"http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"];
AGSMapServiceInfo *serviceInfo = [AGSMapServiceInfo mapServiceInfoWithURL:url error:nil];
AGSDynamicMapServiceLayer *dynLayerInfo = [AGSDynamicMapServiceLayer dynamicMapServiceLayerWithMapServiceInfo:serviceInfo];
NSString *info = dynLayerInfo.mapServiceInfo.serviceDescription;
Just it breaks in first line and I don´t know why!
Attach the error!
NimeshJarecha
You should pass the 'error' like below. It'll be populated if there is an error in creating instance of AGSMapServiceInfo.
NSError *error = nil;
AGSMapServiceInfo *serviceInfo = [AGSMapServiceInfo mapServiceInfoWithURL:url error:&error];
Hope this helps!
Regards,
Nimesh
KOLDODUARTE
Hope this helps!
Regards,
Nimesh
Ok, now it is good, thank you!.. one more.
KOLDODUARTE
I were mistaken, sorry!
Please, someone tries this code:
 UIAlertView *vModal = [[UIAlertView alloc]
         initWithTitle:@"Map Service error"
         message:info
         delegate:self
         cancelButtonTitle:@"Done"
         otherButtonTitles:nil, nil];
 [vModal show];
 [vModal release];
The error is:
NimeshJarecha
You are trying to access the layer information before it finished initialization. When the layer is ready, its loaded property will be enabled. You can then safely access its properties.
if(dynLayerInfo.loaded){
NSLog(@"Initial Envelope : %@", dynLayerInfo.initialEnvelope);
Regards,
Nimesh
