delete shapefile from folder
2476
07-25-2012 01:52 PM
by Anonymous User
Not applicable
Original User: helenchu
All:
How to delete a shapefile from a local folder in vb.net?  I hope I don't have to check one by one file's extension to delete it.
Thank you for your help.
by Anonymous User
Not applicable
Never mind.  I already found out how to do it.  Thanks all.
JORGELAGOS2
Could you please tell me how?
Jorge
by Anonymous User
Not applicable
Hi Jorge,
Sorry I didn't see your question till now.
Below is my function to delete shapefile just in case you still need it.
    Function DeleteExisting(ByVal strFileSpec As String) As Boolean
        DeleteExisting = True
        If Dir(strFileSpec) <> "" Then
            Debug.Print("deleting : " & strFileSpec)
            Dim pFSO As New Scripting.FileSystemObject
            pFSO.DeleteFile(strFileSpec, True)
                DeleteExisting = False
                Debug.Print("unable to delete: " & strFileSpec)
            End If
        End If
        Exit Function
    End Function
DuncanHornby
MVP Notable Contributor
Your code example is simply deleting a file but a shapefile is composed of at least 3 files.
This is not a good way to delete a spatial dataset. You should be using the IDataset Interface or the calling the Delete Geo-processing tool.
Duncan
