Error 010067 when using depression evaluation
3352
07-05-2012 01:47 AM
by Anonymous User
Not applicable
Original User: rubenrommens
When running 'depression evaluation' using archydro I receive the folling error.
[ATTACH=CONFIG]15777[/ATTACH]
Does anyone know what might be the problem?
I've run in the past the module succesfully numerous times, but it seems to disobey my orders this time ...
All my data is stored locally on a external hdd and i've checked if there aren't any spaces in the pathways.
Any help is greatly appreciated !
Kind Regards,
Ruben
TanyaCamacho
I encountered the same error running Sink Evaluation.
Microsoft Endpoint Protection was monitoring the ArcMap process and preventing the sink evaluation process from completing.
Once we added ArcMap.exe as an exclusion from its security scan, the process ran successfully both locally and on our network.
Hope this solution works for you as well.
Tanya
by Anonymous User
Not applicable
Original User: MBoucher21
Make sure your processing extent is correct.
