Find and replace text for all map documents within a folder (mxd)
6056
5
02-21-2012 11:28 AM
by Anonymous User
Not applicable
Original User: mthorpe
Hello.
I'm looking to use a Python script to update the text on multiple mxds without opening each one up. Basically a find and replace function, looped through all MXDs in a directory. I have no real Python experience, so perhaps this has a simple answer. This is the code I have right now.
import arcpy, glob, os
path = r"C:\\"
mxdList = glob.glob(path + "\*.mxd")
for mxd in mxdList:
for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
  if elm.text == "works":
   elm.text = "replaceword"
mxd.save()
del mxd
The error I am receiving now is "Runtime error <type 'exceptions.AttributeError'>: 'str' object has no attribute '_arc_object'"
by Anonymous User
Not applicable
Ok, instead of using trying to edit the aforementioned code to get it to work ... I used this instead:
import arcpy import os import glob  folder = r"\\sample\sample"  oldtext = "Township" newtext = "Borough"  mxds = glob.glob(folder + '\\' + '*.mxd') arcpy.gp.overwriteOutput = True for mxdFile in mxds:     mxd = arcpy.mapping.MapDocument(mxdFile)     for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):         if elm.text == oldtext:             elm.text = newtext     mxd.save() del mxd
Did exactly what I wanted it to do. 🙂
by Anonymous User
Not applicable
Original User: jscheirer
for mxdFile in mxdList:
        mxd.save()
by Anonymous User
Not applicable
Bumping this thread because I can get this script to work ... but not perfectly.   😄
Instead of looping through every MXD in the folder and changing the specified text (changing "Township" to "Borough"), the script only changes the text in the last MXD in the list and saves it.  The folder has about 20 MXD's within it but only the last one is edited.
Any ideas why only the last MXD would be changed?
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Original User: weltiar
If you wanted to do this dynamically how would the code be changed?  I want to create a tool where you can pick what folder and type in old text and the new text.
IanMurray
Honored Contributor
You could add a script to a toolbox and make a script tool out of it.  You would have to make 3 parameters in the tool, one for the input folder(make it a folder type), one for the input text(make it a string type) and one for the output text (make it a string type)
You would have to replace
newtext = "Borough"
with
folder = arcpy.GetParameterAsText(0)
oldtext = arcpy.GetParameterAsText(1)
newtext = arcpy.GetParameterAsText(2)
The 0, 1, 2 pull the first, second, and third parameters you make respectively in the script tool.
Check out this link on how to make a script tool.  It also has links for setting up the parameters.
