Adding raster datasets - raster calculator
1881
01-04-2012 04:09 PM
by Anonymous User
Not applicable
Original User: fpoodat
I am trying to add some raster layers which are a bit different in the area they cover (extent).
Through this adding process, the pixels which are outside the extent of each input raster become "No data" and No data + a value will be No data. so the resultant raster covers the least common area of all the input data.
How can I get the ArcGIS to consider the "no data" value as "0" in this process?
Cheers,
Fatemeh
TimothyHales
Esri Notable Contributor
by Anonymous User
Not applicable
Hi Timothy
It was worked out. According to that blog information, I defined a shape file with the suitable extent. Then through the adding process, I set the extent to the shapefile layer.
Now they are all the input rasters match and so I have got the result with the most extent.
Cheers,
Fatemeh
