Original User: pheersink
I've got 6 files that I hope to use:
- metric contours (lines)
- imperial contours (lines)
- imperial points
- metric points
- streams (lines pointing in the right direction)
- lakes (polygons with an elevation value assigned to them)
The 2 contour files work together no problem. Adding in the points layers to the contours (with out the hydrology layers) or trying the points layers on their own gives me the error message.
