add-in button - mouse down capture?
3216
01-14-2011 10:13 AM
helenchu
All,
I'm trying to built a add-in button which will need to get x,y from a mouse down click.  How do I do it? For example I have Function MouseDownXY so what I need to write on the button Sub Onclick() to make it go to my function?  I'm using vb.net.  Thank you very much for your help.
Function MouseDownXY(ByVal x As Long, ByVal y As Long)
Set pPoint = pMxApp.Display.DisplayTransformation.ToMapPoint(x, y)
End Function
by Anonymous User
Not applicable
Original User: rwelikal
Well, you can make a TOOL or you can make a command.. a TOOL will initiate the code when you CLICK the map.
I would draw a point on click using the ESRI snippet.
    Public Sub DrawPoint(ByVal activeView As ESRI.ArcGIS.Carto.IActiveView, ByVal x As System.Int32, ByVal y As System.Int32)
        If activeView Is Nothing Then
            Return
        End If
        Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
        ' Constant
        screenDisplay.StartDrawing(screenDisplay.hDC, CShort(ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache))
        Dim simpleMarkerSymbol As ESRI.ArcGIS.Display.ISimpleMarkerSymbol = New ESRI.ArcGIS.Display.SimpleMarkerSymbolClass
        Dim symbol As ESRI.ArcGIS.Display.ISymbol = TryCast(simpleMarkerSymbol, ESRI.ArcGIS.Display.ISymbol) ' Dynamic Cast
        screenDisplay.SetSymbol(symbol)
        Dim displayTransformation As ESRI.ArcGIS.Display.IDisplayTransformation = screenDisplay.DisplayTransformation
        ' X and Y are in device coordinates
        Dim point As ESRI.ArcGIS.Geometry.IPoint = displayTransformation.ToMapPoint(x, y)
        screenDisplay.DrawPoint(point)
        screenDisplay.FinishDrawing()
    End Sub
Then I would use another snippet and use that point to get the click location:
    Public Function GetMapCoordinatesFromScreenCoordinates(ByVal screenPoint As ESRI.ArcGIS.Geometry.IPoint, ByVal activeView As ESRI.ArcGIS.Carto.IActiveView) As ESRI.ArcGIS.Geometry.IPoint
        If screenPoint Is Nothing OrElse screenPoint.IsEmpty OrElse activeView Is Nothing Then
            Return Nothing
        End If
        Return displayTransformation.ToMapPoint(CInt(screenPoint.X), CInt(screenPoint.Y))
    End Function
Hope that helps.
helenchu
Thank you very much.  Yes you did help alot just by the word "TOOL"
by Anonymous User
Not applicable
Original User: ellmenreich
hello,
by using the addins i must choose tool or button. i will convert my 9.3 c# code to addin and will prevent an installer with registrations. so in 9.3 i have a tool wich inherit from basetool. the tool opens a form in the onclick method. in the mouse down events i capture the geometry and send it to the form. the new addins tool did not have a onclick method and the button no onmousedown event.
also i cannot call the tool from the form by setting application.currenttool = addins.tool because of it is no command.
so what is the new way to open a form, select somthing like geometrytype (point or line), enable any kind (drawing or editing) of digitze and get back the new geometry to form.
thanks
