ArcObjects Help for .NET (VS2010) Not working
1523
10-13-2010 07:09 AM
LarryWilliams
We have ArcGIS 10 - ArcInfo license and VS2010.
When we try to access the about item under Developer Help we get an error.  We notice that I we have VS2010 Help Library Agent running then the link works.
Is there something we can do to get it to work when VS2010 help is not running?
by Anonymous User
Not applicable
Original User: lftgly
I found the same, after making the mistake of killing it. The Help Library Agent has to be running.
Even then, there are often HTML formatting errors, such as code snippet indentation errors, missing end-of-line characters causing multiple lines of sample code to run together.
And you cannot resize the table of contents window on left side of screen.
I hope it's a 'work in progress', and updated Dev Help will be forthcoming with a future service pack release.
When you find Dev Help topic references to "ArcGIS 9.4", you know it's stale.
In ESRI's defense, they are just following Microsoft's lead in Help format
